trans clutch issue
Old Nov 26, 2005 | 03:48 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
trans clutch issue
ok well i just swapped out my 700r4 for a T5 and i got the holes cut out for the clutch pedal assembly and the shifter plate, tranny is in, pedals are in, clutch fluid res, etc. but i'm having issues with the clutch, i belive its stuck engaged, also i'm having some problems puting the shifter into 1,3,5. its hits 2,4,R just fine. Any thoughts ? pictures are helpful too
Old Nov 27, 2005 | 01:57 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
anyone ? plz
Old Nov 29, 2005 | 12:43 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
cmon, there has to be somone who can help....
Old Nov 29, 2005 | 06:45 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
amazing.. 3 days later not one reply
Old Nov 29, 2005 | 07:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Sounds like the input shaft may be binding on the pilot bearing due to it not being aligned to the crankshaft centerline.
Old Nov 30, 2005 | 01:48 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
so you think the pilot bearing may be crooked or somthing ?
Old Nov 30, 2005 | 07:22 PM
Ricktpi's Avatar
No, the crankshaft centerline is not inline with the input shaft of the trans. This is caused by a bellhousing not holding the trans at the correct position.
Here is an excerpt from Mcleod's Website:
In order for a clutch, transmission and related parts to function properly the bellhousing must have two surfaces parallel to each other. One is where the bellhousing bolts to the motor. Where the transmission bolts to the bellhousing is the other. To check this, use a dial indicator with a magnetic base. Attach the base to crankshaft and indicator to (top) or transmission mating surface. Turn flywheel and mark the surface with something you can read (chalk, magic marker, etc.). Maximum runout is + 0.005 to -0.005.
To correct out of parallel; take bellhousing to someone that does Blanchard grinding (most steel flame cutter people have one). Place the engine surface down on the table and have them grind the transmission mating surface to bring it into parallel.
Center Hole or Bore Out of Alignment:
If center bore doesn't run true to the center of the crank or pilot bushing, the clutch disc will suffer and possibly effect the transmission front bearing too. Irratic clutch engagement and disengagement can occur. Sometimes in the center of the disc will break completely out if this problem is not corrected.
To check alignment in the car McLeod has a dial indicator tool that attaches to the crank with a magnet or use a regular magnet base indicator holder. Once the base is secure, set indicator dial at "O". Slowly move the flywheel and observe the indicator. The maximum McLeod recommends for the housing to be out alignment is +0.008 to -0.008. When watching indicator it is best to mark the center bore in four places then read and record the indicator reading at those four positions. (We recommend the four positions be like a plus sign in math Example +.
Correction of bellhousing alignment is usually done with off-set dowel pins. Check with your local speed shop for appropriate part# and off-set. If your bellhousing is not a McLeod and it runs our of alignment more than 0.040 out on the block, then we recommend purchasing a new McLeod Housing.
Old Dec 1, 2005 | 03:03 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Definitely check what Rick said out, but I have a question for you, are you using an aftermarket shifter?
Many times the stops can be adjusted incorrectly and cause you not to fully engage in gears.
Also, have you checked / bled the slave cylinder?
Old Dec 1, 2005 | 03:07 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
stock shifter. thing is also, i went under the car, and noticed presure is being given as if the clutch pedal were being pressed, without it being press.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
mizz0313
Aug 12, 2015 06:45 AM
rsrmoore
Aug 7, 2015 08:44 PM
