Is there a way i can get the transgo instructions/video online?
Old Nov 28, 2005 | 05:18 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I bought a transgo kit and left the directions outside with the trans... the moisture gathered on it and tore them apart. i also didnt have the video and wanted to see it. do you know where i can find either of these. I really wanna be precise when I do this. Also, the trans is out of the car, do you guys have any helpful suggestions i can use during the install to make things a little easier? also, theres that one 13mm screw holding that thing down on the valve body, i wanna be sure i put it back on right when i do. thanks a lot guys.
Old Nov 29, 2005 | 04:19 PM
ZZ4 86 Z28's Avatar
darn. also i just went outside and during the storm the cover was blown off the trans...so it got some water in it most likely with it wide open. i sprayed it down inside with some brake cleaner. should i do anything else?
Galaxie500XL
Feb 1, 2020 04:53 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
Giocio
Oct 1, 2015 12:20 PM
steimel94
Sep 23, 2015 12:48 AM
italiano67
Sep 22, 2015 08:42 AM
