Swapped motor now have vibrations
Old Nov 28, 2005 | 10:28 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
I swapped the 2.8 motor (automatic) out of my 87 firebird with a 2.8 out of an 89 camaro (5-speed). The motor out of the camaro had no flex plate so I just threw on the one from my car. Once I got everything back together the car vibrates like crazy. What do I need to do to fix this problem?
Old Nov 29, 2005 | 05:32 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I'm not too familiar with the 2.8 but it sounds like you need an externally balanced flywheel. But since you used basically the same motor to swap it with, that might not even be the case. My next question would be does it vibrate while parked or driving or only on acceleration or deceleration?
Old Nov 29, 2005 | 04:34 PM
sixbanger's Avatar
it vibrates most noticeably when idling in park.
Old Nov 30, 2005 | 12:28 AM
1981LT1's Avatar
Engine: LT1; LT1
from what I can tell, in 1988 the engine was switched to an internally balanced unit. Thus, your flexplate is probably weighted and throwing the assembly off balance.
http://www.engine-parts.com/GMV6/history.html
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
