Another TCC Lockup Q
Old Nov 29, 2005 | 05:34 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Who can get me a fluid circuit diagram for TCC lockup? They might be found in the GM service manual, but I don't have one (yet). I have a feeling that the TCC valve in my trans is a little sticky, seeing as how it now locks in First at a dead stop, and then releases as I accelerate.
Also, if the valve IS dirty, can I clean it somehow, say, when I install a shift improver kit? If the TCC doesn't work afterwards, I won't be much worse off because it already works when it wants to.
Old Nov 29, 2005 | 05:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've got one for an earlier revision of the 700R4, but it changed in 1987. IIRC it's pretty simple in the later ones, apply pressure to the TCC comes from the 2nd gear circuit, but is exhausted by default. When the solenoid is energized, the TCC checkball blocks the exhaust port and the TCC locks.
Old Nov 30, 2005 | 12:13 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
<img src="http://www3.telus.net/~crussel/tcc_applied.gif">
<img src="http://www3.telus.net/~crussel/tcc_released.gif">
UltRoadWarrior9
Apr 28, 2020 10:39 PM
seiplentz
Aug 19, 2019 06:02 PM
92camaro350cci
Oct 14, 2015 09:29 AM
customblackbird
Oct 1, 2015 04:30 PM
ramicio
Sep 28, 2015 01:18 PM
