9 Bolt Question
Car: 1985 Camaro
Engine: 383
Transmission: 700
9 Bolt Question
I have an 85 Camaro with a BorgWarner rear housing assembly. It currently has a 3.27 gear ratio, but I would like to upgrade it to a 4.10. Does anyone know if this is possible, and if so, where one could find the 4.10 ring gear and pinion?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yes.... Next time you could probably find results faster by using the
www.9bolt.com has various gears he gets them over time. I think he even offers some 4.56 and higher ratios too.
Randy's Ring And Pinion is where I got my 3.73 at... but that's the only ratio they carry. http://www.ring-pinion.com/
There's also other places too.
Car: 1985 Camaro
Engine: 383
Transmission: 700
9 Bolt Question
I've been on (9bolt.com) before, but all they seem to have are used parts. Was wanting something new, along with an installaion kit and possibly bearings. Also, I have run numerous searches, but the highest gear ratio found so far is a 3.70:1.
Thanks for your help!
Car: 1985 Camaro
Engine: 383
Transmission: 700
9 Bolt Question
Thanks for your response. Believe your comment about not finding a 4.10 for a 9 bolt is probably true. I've searched numerous sites on the internet, but cannot find anyone who supplies this ring and pinion gear ratio. Again, thanks for your help.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
