700r4 to Turbo400 (TH400) Tranny Swap. DIY HELP
Car: 1986 Trans Am
Engine: LG4 305 (The wheel's still spinnin but the mouse is dead!)
Transmission: A4 Automatic (Little Rusty Wheel) heh
Ok, First I have the following,
1986 Pontiac Trans AM 305 with A4 700r4 trans
I have been given a TH400 or Turbo400 if you will, transmission....
I want to put this TH400 in my trans am.... I want to know the following:
1: Additional Parts Needed?
2: Modifications Needed?
3: Any guides/websites outlining the swap available?
I have searched on the board and found various answers and would hope to find a more definate one. Please assist.
The th400 has been rebuilt professionally.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
TH400 slip yoke and shorter driveshaft
A crossmember since the TH400 rear mount sits back a lot farther.
Some way to attach the torque arm
Electric kickdown
The crossmember and torque arm solution can be done with a Spohn torque arm conversion.
Electric kickdown
Car: 1986 Trans Am
Do you have the spohn's part numbers or link?
Thanks for the reply.
Car: 87 IROC L98
Click the banner at the top of the page. www.spohn.net
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
There's a solenoid in the trans that can be activated by a micro switch on either the throttle linkage at the carb or mounted at the gas pedal(this is how the factory mounts it).
I know TCI and B&M make kits just for this.Others probably do but those are the first that come to mind.You can fab your own too.
Just for curiosity why do you want to switch from the 700R4 to the TH400.Unless you're pushing some very serious power the added weight and power consumption really isn't worth it.The 700 can now be built to be very reliable or use a TH350.And maybe sell the TH400 to cover your cost.
Car: '88 IROC-Z medium orange metallic
Start with the sticky post up top. It covers everything briefly. It's going to run you more than a couple bucks to get it in and in my opinion, for your application it wouldn't be worth it. Putting a th400 behind a 305 makes almost no sense. Not worth losing overdrive, it's heavier and will suck up more HP before it makes it to the wheels. If I were you I would sell the th400 and buy a stall converter and shift kit for the 700R4.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Tony did a great job with his write up. Have a look at the top of the page.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
darwinprice
17
Oct 11, 2015 11:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
