B&M Megashifter
Old Dec 18, 2005 | 09:36 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
B&M Megashifter
Ok i have a megashifter in my car. It has been a wile since i have acturaly looked at it. Is there any way i can modify it so when i pull the lever i can go from park/or reverse to 1st. I dont like goin down to D and then 2 then 1. The main reason i am asking is i am planing on puting a manual valvebody in the trans and it dosent seem like the trans would like going into 3rd first sitting still
Old Dec 21, 2005 | 07:58 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
anyone know?
Old Dec 24, 2005 | 02:20 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
When you do the manual valve body, install a reverse pattern unit that way what used to be third will now be first and you will pull back instead of pushing forward for each following shift.. Make sense?
Old Dec 24, 2005 | 10:52 AM
NHRA427's Avatar
Car: 94 Trans Am
Engine: LT-!
Thats a good idea but i didnt like not being able to go from 3rd to N without going thru the rest of the gears. when i got thru with a run i like to just pop it in to N
Old Dec 24, 2005 | 11:12 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i don't think there is a way without modifying the gates yourself
it's designed to do that to prevent mis-shifts and what not
Old Dec 25, 2005 | 12:52 AM
Engine: 355 / 355
Going from third to neutral is a good way to grenade your transmission espically a th400. At the end of the run you should be leaving your car in third until you can slow it enough to downshift. If you are really serious about a consistant drag car you should probably get rid of the p.o.s. megashifter and get a quarter stick, cheetah, or bandit. they are much more accurate and reliable.
Old Dec 25, 2005 | 10:17 AM
Digger's Avatar
I have the Mega shifter and the revers manual valve body and my car will actully free wheel when I shift it through second and first to neutral. So it does not hurt it any. I dont know if they are all like that but thats my experience with them.
Digger
unknown_host
Aftermarket Product Review
Aug 11, 2001 08:44 AM
jayman350
May 18, 2001 08:23 PM
jimbo
Mar 14, 2001 05:35 AM
STL1994
Feb 17, 2001 02:41 AM
Fastbird
Nov 5, 2000 10:47 AM
