what is this part called?
Old Dec 24, 2005 | 08:44 PM
PJ POLING's Avatar
Car: 1986 Z28
Engine: 5.0L
i have a 86 Z with the T-5 and i need to know what you call the part or clip that connects the clutch pedal to the clutch cable (has anyone had to replace this?) when i got the car it was broke and the owner before me used a zip-tie to hold the two together, i didnt know that when i bought the car also has anyone used the poly tranny mount ? is this a good part or not needless to say mine is broken and i get a huge clunk when i start to go i need to get this fixed really fast
thanks
Old Dec 24, 2005 | 10:02 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
clutch cable????....in an '86??? it should be a hydrolic clutch, with a master cylender attached to the pedel (via a rod) and a slave cylender attached to the trans, they did away with the mechanical linkage in 84, and they never used a cable, they used a Z-bar setup in 82 and 83, also go with the polly, the trans mount is notorious for breaking in it's stock form, I've had a polly one since 98, and it's stood up to a 500 hp engine since then, no probs.
Old Dec 26, 2005 | 09:43 AM
PJ POLING's Avatar
Car: 1986 Z28
Engine: 5.0L
it is a hyd. system but when you look down there you see the pedal and a cable going outside the car. thats all i can see so what holds the pedal to the "cable" going outside of the car
thanks
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
