Long 1-2 shift
Old Dec 28, 2005 | 04:30 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Long 1-2 shift
Ok , before I put the tranny in my Iroc I went through with a freshen up of the tranny. New clutches and steels, new Kevlar band, Corvette servo, 13 vane pump kit. When the tranny is cold it takes along time to shift from 1-2 and it isnt firm. Other shifts are very quick when your WOT but feel firm. would a shift improver kit make the shifting better or would a shift kit be needed?
Old Dec 29, 2005 | 10:59 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Anybody??
Old Dec 29, 2005 | 08:20 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
It might be something internal, but since it's easy to do, did you install/adjust your TV cable correctly?
Old Dec 29, 2005 | 08:23 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Actually I hooked up the cable and adjusted it and it wouldnt downshift so I disconected it from the TB .
Old Dec 30, 2005 | 03:30 AM
Pro Built Automatics's Avatar
The TV cable is an "absolute" and it must be adjusted so that WOT the TV cable is tight or with a 1/16" plat at most. Yes, the
modified" Trans-Go Performance Shift kit will help.
Old Dec 30, 2005 | 06:09 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
What would happen if I dont hook up the TV cable. I like how I can just floor it and not have it kick down.
And what do you mean by a modified shift kit, do you sell one?
Old Dec 30, 2005 | 05:36 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
700r4 ?
Tv cable required
however i have driven a third gen camaro with 700r4 and the cable not connected- unknowingly
i bought the car that way
what it would do is it would act alot like a shift kit
it would wind up high in each gear and crash hard into the next one
if you drove it easy then it was even worse
you had to drive it hard to keep it from jerking the car so hard every shift, when it finally did shift
its a big no-no
bad for the tranny
really really bad
good luck
Old Jan 2, 2006 | 12:25 AM
The modified Trans-Go Perormance Shift kit allows for smooth 1-2 part throttle shifts, and firm WOT shifts. You cannot eliminate kick down with out going to a full manual forward pattern setup from Trans-Go. Yes, I carry these.
F-body driver
Mar 6, 2023 11:44 AM
TheTraut88
Sep 11, 2015 05:16 AM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
TheTraut88
Sep 7, 2015 05:22 PM
tonys91rs
Sep 2, 2015 07:07 PM
