What the hell??Engine keeps going!
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
What the ??Engine keeps going! Need help
So here is what happend I was coming back from dropping my girlfriend off at her house, on my way home I was near my house.. then something happend.
I came to a stop, and stoped (It is raining both light and hard showers at random times here in socal) I then step on the gas kinda hard and the wheels start spinning and then I step on the brake and the camaro is still going as if im stepping on the gas hard and hear the engine and transmission working very hard and loud!!! and then go into Panic mode and try to go to Nuetral then park and the transmission makes some loud *** noise so then I finally hold down the brakes and put the car in park and turn off the car real fast. And then turn on my emergency lights and call my brother he doesnt answer. So then I wait there for like 5 minutes and decide to turn the car back on and so I did.
The Car turns on and I drive off like nothing has happend everything is running smoothly. Something did happend? I didnt hydro plane I know that. Could the transmission gone out of gear or something because of the wet tires not grabbing could this cause something wierd like this to happend?
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Originally posted by phoenix305
sounds like sticking throttle linkage to me.
replace it or lube it...mine has done the same thing... i found the cable had cut a groove in the housing at one of the bends and was stopping it from moving freely (it was a cable for a v6 which is a little too long)
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
sounds like a stuck throttle cable to me! can lube it if you prefer or replace it like he said
but i would do something about it retively soon.
but i would do something about it retively soon. Senior Member
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
why do i always read on here where people with a stuck throttle or some similar thing put there car in park to stop? it will definitly work but neutral + brakes will do the same thing but not destroy your trans. it may take the strain once or twice but it will do damage. at the least it will shorten the life of you trans and rear. if ya throw it in neutral then hit the key to shut it off that is the best thing you could do or even just shut it off and use the resistance of the engine to slow you down. I have had the throttle stick on me in 3 different cars for different reasons and all you have to do is turn it off, put it in neutral, and pull off the road.
mhatfield 14
Oct 24, 2015 07:48 AM
novaderrik
Aug 10, 2015 12:44 PM
