So apparently the t5 i want is without a torque arm mount.
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
But i really want this one. where can i get one, and how much am i looking at. if you got one for sale, feel free to let me know either in this thread or in a pm.
oh yea, and what about using the same one from the 700r4? thanks a lot.
anybody? this is kind of important and you guys are usually pretty reliable. i bought a t5 with nothing attached and i have an auto in my car right now and all was working fine. will the torque arm mount correctly without any parts?
Car: 83Z28 HO
Transmission: G Force 5 speed
duh, my bad. ok i have an auto, it recently broke, but everything was hooked up before and working fine. i bought a t5 wc from an 88 305 camaro. i know the torque arm goes to a torque arm mount which goes to the tranny. a torque arm mount was not included with this tranny. will i be able to use the torque arm mount that is on the car already, or is it different for the manual trannies. sorry about being vague, im usually pretty good at explaining myself.
by the way its an 86z28 that came with a 305/700r4 at first.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Different part numbers between manual and auto. Check the following:
Torque arm outer (85-90 W/M39) (86 W/MC4) (87-90 W/MK6), 10034259.
Torque arm inner, 10034261.
Nut, 11502812
Washer 9439513
Bolt, 11500930
Bolt, 11504745
You might check with GM.
JamesC
Nut, 11502812
Washer 9439513
Bolt, 11500930
Bolt, 11504745
JamesC
but can you make it work? im not talking about the actual torque arm, just the mount.
The above part #'s are for the inner and outer torque arm bracket/mount for a manual trans (It's kind of a clam shell affair). The part #'s for manuel and auto are different, so my guess is that they are not interchangeable.
JamesC
JamesC
where did you get yours?
19doug90
Jul 3, 2007 08:53 AM
