are all thirdgen 10 bolts the same?
Old Jan 5, 2006 | 10:56 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
will a 10 bolt from an 86 TA bolt up the same as the stock 10 bolt in my 87 Camaro? I would think that it would be the same, but i just want to make sure. also, if it makes a difference, it currently has drum brakes, and the potential new rearend has disc brakes.
Old Jan 5, 2006 | 11:12 PM
CrazyHawaiian's Avatar
Car: too many ...
They are direct swaps but there were differences as far as brakes (Iron/Alum Drum, Iron Caliper, PBR Caliper), differentials (open or posi), and axle splines (26 spline or 28 spline).
Old Jan 5, 2006 | 11:16 PM
Engine: 357
mine currently has an open differential and 2.73 gears. the rearend i'm considering buying has 3.73 gears and a posi, which is the main reason for switching. also i'm pretty sure they are both 26 spline axles. basically i assumed it would be the same but thought i should probably make sure before buying it.
Old Jan 5, 2006 | 11:20 PM
Car: too many ...
If that was a factory 3.73 then its a G92 rearend, go for it.
Old Jan 5, 2006 | 11:30 PM
Engine: 357
i don't know if its factory or not??
https://www.thirdgen.org/techbb2/sho...hreadid=337642
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
