t56 swap ?
Old Jan 7, 2006 | 01:47 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
t56 swap ?
does anyone what this is used for Dakota Digital SGI-5:
Old Jan 7, 2006 | 02:31 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
im pretty sure its used to convert the t56's electric VSS signal to a mechanical one for mechanical driven speedometers.
Old Jan 7, 2006 | 02:49 PM
n8sz28's Avatar
Car: 85 camaro z28
do you only need it if you have a gear driven speedo? if i converted to a electric speedo would i need the system
Old Jan 7, 2006 | 04:09 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
nope, if you convert to electric speedo you shouldnt need it.
Old Jan 7, 2006 | 07:28 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
No, you are thinking of the Abbott cable X box. The Dakota box is an interface of electronic signals for conversion purposes on your VSS
Old Jan 7, 2006 | 07:39 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
i knew a voice of experience would chime in....thanks mr smarty pants!
Old Jan 7, 2006 | 07:43 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
so the dakota must be the one that has the dip switches you can change to recalibrate when you switch rear end gears right?
Old Jan 7, 2006 | 07:46 PM
406TPI's Avatar
Car: 1985 IROC-Z
Yes it has them....but so does the Cable X box
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
