9-bolt to 10-bolt question
Old Jan 19, 2006 | 09:25 PM
net_coma's Avatar
I am having difficulty locating a replacement 9-bolt. I have located a decent 10-bolt. Will all of the hardware from my 9-bolt fit and function with the 10-bolt? I hate it when a simple chore turns into and evolution.
Old Jan 19, 2006 | 09:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
is it a disk 9bolt to disk 10bolt?
every thing else suspension wise should work.
the only things i can think of that might be changed is the parking brake cable. i'm not sure if they 9bolt calipers are the same as the 10bolts. depends on the year i think
what year car did the 10bolt come out of?
Old Jan 19, 2006 | 10:07 PM
net_coma's Avatar
The 10-bolt is being removed from a 92 Z-28 with disk brakes. It is replacing the 9-bolt in my 88 IROC with disk brakes.
Old Jan 20, 2006 | 08:25 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Different parking brake cable and same for the dics brakes. You will have take a closer look at them side by side and see what will fit.
Old Jan 20, 2006 | 08:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Jan 20, 2006 | 12:39 PM
net_coma's Avatar
Thanks guys, I will get the brakes also and save myself some time. JamesC, great info and thank you.
Old Jan 20, 2006 | 08:23 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
whats wrong with the mighty 9bolt besides the 90% chance it has the iron calipers
Old Jan 20, 2006 | 11:26 PM
net_coma's Avatar
Howls like a wolf in heat...yes iron calipers. Operation is smooth, no clanks or bangs may be bearing(s).
Old Jan 21, 2006 | 07:44 AM
Engine: ls1, LB9
ah why give up on it? I would still get the other brakes but.... the 9 bolt is a good rear
Old Jan 21, 2006 | 06:41 PM
net_coma's Avatar
the 10 bolt has been recently freshened and the price is right. if the price stays right I will install it and dink with the 9-bolt later. the change may also help resolve the vibration i get at 70. if it stays with the car and does not change then maybe axels were not the problem.
MustangBeater20
Oct 29, 2022 09:20 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
