T5 tranny to bellhousing studs?
Old Jan 20, 2006 | 03:33 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Hey guys
Can I use this it would make life easier when
putting the t5 up to the bellhousing ?
http://www.jegs.com/webapp/wcs/store...1651&langId=-1
Old Jan 20, 2006 | 03:35 PM
Not really.... even if they were the right size (T-5 to BH is 10mm)
Putting in a T-5 is easy, about the easiest manual trans there is because it's so light; as long as the clutch disc is aligned properly.
Old Jan 20, 2006 | 03:44 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Now that Im thinking more about it
once the tranny is through the pilot bushing and clutch that
should hold it up I guess.
On the size of the bolts not sure what it is now
because someone posted that they use m12 x1.25-15 bolts
is that 10 mm?
Old Jan 20, 2006 | 03:58 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
I guess Ill have to go to the dealer in my area
just in case
Dont want to get the wrong bolts anyway
im still trying to piece it all together missing
hardware for the slave cylinder and master cylinder
so on and so forth
thanks
Old Jan 20, 2006 | 04:19 PM
That could be right; they might be 12mm, not 10mm. I might have some neurons crossed somewhere.
I know for sure they're metric though.
Old Jan 20, 2006 | 04:55 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
not a problem I appreciate your responses
good day sir
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
AUZ28
Oct 3, 2015 06:28 PM
jtwoods4
Sep 3, 2015 05:39 PM
