T-56 clutch fork
Old Jan 27, 2006 | 08:33 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
T-56 clutch fork
Any one know an easy way to release the clutch fork with a T-56 trans and a pull style clutch?
Old Jan 27, 2006 | 12:23 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Not sure what you mean by release, but here is the parts breakdown.
Old Jan 28, 2006 | 01:58 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
it's on a car i'm working on at work (94 camaro). in order to get the trans out you have to pull the clutch fork out of the throw out brg.. the fork would not pull out until i had the tranny loose, and the bell housing loose , then with everything loose and kinked around i could get a wrench in there to loosen the bolt on the fork so that it would pull out of the t.o.brg.
seems that there should b a easier way. with the fork bolted down it will not go over the detents in the fork to pull it out , or put it in!
Old Jan 28, 2006 | 02:04 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
that pic is good on the trans and the clutch . but the pic of the fork and ball is for a push style clutch. the fork has a slot in it that a pivot goes through that bolts to the front of the trans .
i'm wondering if the pivot has been cut down ? becuase of the fact that you cant slide it out with out loosening the pivot bolt?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
mygta87
Sep 14, 2015 10:36 PM
