T5 Pedal Travel Question
Old Jan 27, 2006 | 02:14 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I have a T5 behind my small block. The problem I have is I must push the pedal almost all the way to the floor to get the clutch to disengage. Is this common? Can an adjustment be made? I bled the system well but the problem still exists. I would like it to disengage half way through the travel to facilitate a quicker shift. Right now I have a short throw shifter but I'm slow because of the pedal travel.
Old Jan 27, 2006 | 02:37 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Leaks? Worn clutch? There is no adjustment on the stock T5 setup. If you need a new master or slave I have both I only used for test purposes. I ended up with a Mcleod master cylinder & hyd TO bearing.
Old Jan 27, 2006 | 04:05 PM
wesilva's Avatar
Transmission: 200R4
No leaks. Brand new clutch. Hmmm..... You have a PM, Rick
1992 Trans Am
May 10, 2023 07:19 PM
bigdavesiroc
Sep 14, 2015 10:51 PM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Aug 16, 2015 12:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
