T56 questions
Old Jan 28, 2006 | 08:21 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
T56 questions
I purchased a 91 rs from 91rs218 he has done the T56 swap I'm curious if a stock 92 camaro clutch master cylinder will work or do I have to get one for what ever year the T56 came out of? Also He told me the reverse lockput needs to be purchased because when the car is running for the life of me you can't get her in reverse it has to be turned off and then restarted once in reverse.
Old Jan 28, 2006 | 11:20 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
yes you need the t56 hydraulics. As far as the reverse goes, i haven't bypassed my solenoid in the trans and i have to "put" it into reverse when i need it. It takes a little shove but it will go.
Old Jan 28, 2006 | 11:33 PM
michael's Avatar
Car: 1991 Formula
so i have to find out what year the t56 came from and get that clutch master cyl?
Old Jan 29, 2006 | 01:35 PM
1981LT1's Avatar
Engine: LT1; LT1
anything from a 93 to 97 f-body should work. I don't see why they would be different. I got mine from www.gmpartsdirect.com for about $150.00 (the whole assembly) shipped and ready to go. I don't remember the part number though.
Old Jan 29, 2006 | 04:20 PM
michael's Avatar
Car: 1991 Formula
anyone know the bolt size for the torque arm bracket on the side of the trans. I need the one that bolts the outer bracket to the inner bracket the bolt is missing from mine so I can't drive it :-( its the t56 manual trans
Old Jan 29, 2006 | 05:50 PM
1981LT1's Avatar
Engine: LT1; LT1
i believe it's a 15mm
Old Jan 29, 2006 | 07:47 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
you can use the stock 84-92 master cylender...you HAVE to use the line and slave cylender from a 93-97 for it to work...breakware makes an alluminum one W/ a bleeder screw...the part # is 10380, and blieve it or not is is sold at autozone...also yes the lines have all the same ends...so you can put the braided steel line on the T-5's master cylender and it will work.
Old Jan 30, 2006 | 10:30 AM
michael's Avatar
Car: 1991 Formula
bolt is a m10 1.5x30
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
