quick 9" rebuild question
Old Jan 31, 2006 | 05:32 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I was wondering if I could take my ford 9" open carrier (28spline 3.89) and rebuild it to work with posi?
Are the casings different in any way shape or form?
Old Jan 31, 2006 | 05:38 PM
ede's Avatar
ede
sure all you'd need to do is swap carreirs. if the axle spline is differant then you'd need axles to match the carrier.
Old Jan 31, 2006 | 05:41 PM
Dirtbik3r's Avatar
alright, so im guessing the open carrier is not able to be converted. Guess it is off to ebay.
*EDIT*
I think I'm confusing my self. The outside is the case. Correct? And the carrier is inside the case... Is this right so far? So I would be able to keep my stock 9" iron case? If so, any suggestions on what to get such as a kit (part numbers would be helpfull). My transmissions and driveline instructed said he would help me out if i did the research.
Old Jan 31, 2006 | 06:28 PM
Dirtbik3r's Avatar
Any ideas/input about my parts list?
STR-R-542043
FPP-2302
MSR-9508T
Needs seels for the above^
Rough Total = $500
Would this work with my third member casings and yoke??
Old Jan 31, 2006 | 09:01 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
well here the best info I have ever gotten on the ford 9 inch rear end.. just follow the link
http://www.ford-trucks.com/article/i...ear_Setup.html
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Infested
May 22, 2018 11:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
hokis
Aug 9, 2015 03:57 PM
