removing a 5 speed?
Old Feb 1, 2006 | 12:20 PM
88firebirdguy's Avatar
Car: 83 recaro, 82 grandprix, 72 skylark
removing a 5 speed?
whats the easyiest/fastest way of removing a 5 speed behind a 2.8? i need to replace my throw out bearing.
when i did my clutch job i pulled the tranny out with a floor jack with a wood plank and it ended up falling and almost crushing my hand. then installing i had to get right underneath the center of the car and pull the trans up ontop of me and lift it up into place so i could get it aligned but it almost killed me, had stomach and back pains for a few days
im just looking for the best/safest way to do it this time.
Old Feb 1, 2006 | 01:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
more people...
I didn't think the 5speed was all that heavy...?
I've used a tranny jack (useful if the car is on a lift), and a 6'4" 300lb yard ape, both of which I assume you don't have
A jack is sadly your best option, another person to balance it, while you line it up might save your torso this time.
Old Feb 1, 2006 | 02:05 PM
yah its not that heavy but when you are laying on a cement floor and car very low to the ground because just using some jack stands with very little room to work its bad.
Old Feb 1, 2006 | 02:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, I figured that meant it'd have less room to fall, before it hit you
I throw 2x8 wood below my jackstands, and below the jack, to get it high enough in the air.
InfinityShade
Aug 22, 2015 08:00 PM
perZ
Aug 15, 2015 01:17 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
