9 bolt axle seal replacement?
Old Feb 5, 2006 | 01:35 PM
honkeytonk_man's Avatar
Car: 1988 IROC-Z
Engine: e-tec headed ZZ-4 350
Transmission: t56
Axle/Gears: 9 bolt 3.7 posi
I plan on replacing the iron caliper disks on my 9 bolt with ls1 pbr stuff. When i pull my 9 bolt axles are there seals I am going to have to replace? If so does anybody have part numbers and sources? Are there any special tricks to axle removal and intallation in these rears? There are no c -clpis so I should be able to do everything from the axletube ends right?
Old Feb 5, 2006 | 02:36 PM
ede's Avatar
ede
you shouldn't have to replace anything if there isn't a problem before you start. no real tricks, either use a seal puller or a piece of pipe as a driver to remove the seals. you can get to everything from the outsdie, no need to pull the cover.
Old Feb 6, 2006 | 11:42 AM
Car: 1988 IROC-Z
Transmission: t56
thanks I appreciate the insight
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Leggman1
Aug 6, 2015 04:15 AM
