Tranny Problem: Doesn't like hills?
Old Feb 6, 2006 | 12:16 PM
Z28GIRL's Avatar
Car: 85 Z28
HI,
I am running a rebuilt 700R with a Bowtie Overdrive lock-up kit and a B&M shift improver kit.
The car runs fine when level, but when I try to accelerate on an incline the car will not speed up at all.
Also, it seems to have a tendency to "jump outta gear" when going from 2nd - 3rd and I have rev up on it and let it fall then it will sort of "bump" back into gear. It seems to do this more when it is cold, not when the car has been warmed up. Any suggestions, things to check?
Thanks!
Old Feb 6, 2006 | 12:32 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
TV cable adjustment & fluid level. If thats okay, then it's rebuild time.
Old Feb 6, 2006 | 12:34 PM
Z28GIRL's Avatar
Car: 85 Z28
Just rebuilt it in July, but I will check the cable and fluid again.
Old Feb 8, 2006 | 12:35 PM
Z28GIRL's Avatar
Car: 85 Z28
Fluid is fine, cable is fine.
Old Feb 8, 2006 | 01:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's done this since it was rebuilt, it sounds like something wasn't done correctly.
Old Feb 8, 2006 | 10:43 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
agreed.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
