Still drives in Neutral???
Old Feb 8, 2006 | 09:11 AM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Ok, this is kinda wierd. Say I'm rolling through a parkinglot (8-10mph) and I pop it up to neutral to throw a rev at sombody. Ok, when I do this, it revs normally but I can feel it pulling alittle, like the car surges forward, only slightly. I've done it at slower speeds, and the pull is more prominent. Is this somthing simple as the linkage not going the full travel, or is it somthing in the torque convertor? Or other tans internals? The car is a 92 RS with a 3.1 V6 with 127,000 miles on it.
Thanks alot,
Max
Old Feb 8, 2006 | 11:31 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Shift cable is probably out of adjustment.
Old Feb 8, 2006 | 06:01 PM
southern_boy79's Avatar
Car: 84 Z-28
Engine: 355 cu. in.
in my experience at least, if you have a car up on a lift or stands etc. and put it in neutral it will turn the tires like its in a gear. thats not all cars ive seen though just most but ive never seen one that you could fell pulling while on the ground. ????
Old Feb 9, 2006 | 12:46 PM
myvmax1's Avatar
Car: 91RS, 91RS
Well, it dosent really pull hard, and it dosent do it constantly, or all the time. Like I said above, if I were to slip it into neutral and gun it, it would pull only SLIGHTLY for just a seccond, then it wont do it again.
Just confusing
Max
Street Lethal
Apr 30, 2019 12:14 PM
5spdcamaro
Aug 28, 2015 02:12 AM
86IROC112
Aug 21, 2015 12:39 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
cRoe4
Aug 7, 2015 08:46 PM
