U Joint Bolt Torque
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
U Joint Bolt Torque
I have an '87 IROC-Z with the 7.625 10-bolt rear and stock driveshaft. What is the proper torque for the bolts that retain the rear u-joint on the pinion yoke?
Thanks. -Neil
Thanks. -Neil
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive always tightened them by hand with a wrench.
good and tight is the only spec you need.... obviously dont overtighten it a stupid amount, but its not a critical torque spec.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
18-20 ftlbs. Any more & you can distort the caps. Make sure you use a locking nut or lock washer. My brother in-law chucked a drive shaft out of his race car by not doing this.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
