700R4 Problems
Old Feb 11, 2006 | 08:29 PM
fishheadback's Avatar
700R4 Problems
I have a 700R4 transmission that is having some problems. I have installed a Stage 2 shift kit, Corvette shift servo, and an upgraded tv boost valve, an aftermarket cooler, and a 2500 stall converter. Now for the problem, the transmission is very sloppy. It seems like it has no main line pressure. From a dead stop it is slow to engage, and has no reverse. It seems like it goes into second but it is so soft you cant hardly tell if it does or not. I really don't think the clutches are bad, it seems like something else. I'm lost. Any help would be very beneficial. Thanks.
Old Feb 11, 2006 | 09:16 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Check the boost valve. You may have installed the inner part upside down.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
