what gear to get
Old Feb 12, 2006 | 10:38 AM
Duke901's Avatar
Car: 89 Formula
what gear to get
I have a 438 bb in my 85 iroc and i cant decided if i want 410 or 456 gears. The motor has 11-1 comp, 595 lift cam, stock cast heads with 2.19 1.88 valves. torquer 2 intake, and a holley 800 cfm carb. The motor is backed by a turbo 350 with a 3200 to 3600 stall.
Thanks Mike
Old Feb 12, 2006 | 03:11 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
really need to know what size tires you are running. a friend ran my car with a 454 and 4.10 and 28 inch tires and was running low 7's in the 1/8. past the 1/8 he needed more gear or less tire. i am running sbc in the same car with 26 inch tires and am redlining around 1000 foot (that is how long the track i race at is). he had to run the 1/8 in his class. i have to run the 1000 in mine. his new car has 4.88 and 28 inch tires and works great in the 1/8 and redlines 1000 foot . both cars have th 350 trans with 4000 stall.
Old Feb 12, 2006 | 05:36 PM
Duke901's Avatar
Car: 89 Formula
I want to run a 28 tall tire
Old Feb 15, 2006 | 04:54 PM
Duke901's Avatar
Car: 89 Formula
So what do you think i should run
Old Feb 15, 2006 | 05:02 PM
91drag's Avatar
Engine: 350,289
imo i would go for 4.56 to run the 1/8
4.10 for the 1/4 but that is my
Old Feb 15, 2006 | 05:05 PM
91drag's Avatar
Engine: 350,289
i also talked to a friend that builds race chassis and runs a 41 ****** drag car he runs 5.12 or something like that so me i dont redline at 9500 like he does i keep mine around 6500
Old Feb 15, 2006 | 05:06 PM
Duke901's Avatar
Car: 89 Formula
ok cool, i did the gear calulater and with the 4.56 it showed at 6500 i would be at 115 in third with a turbo 350.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
