TH350 weak points??
Old Feb 16, 2006 | 01:31 PM
Guest
Guest
Posts: n/a
TH350 weak points??
ok guys i'm swaping a TH350 into my 1991 firebird.. now this isn't a "how do i swap a TH350 into my car" thing... i already have a TH350 but i want to rebuild it... i can do a stock rebuilt with no problem BUT this transmisison is goign to be behide a 550HP small block with a 5000 stall 8" convertor this car i HOPE will be in the low 12's to high 11's i know the weak points in the 700R4 but so far the onlything i can find is that the TH350 has a weak sprngs... btu what else ? i want to built this tranmission with a rev. manual vavle body and a transmission brake so does anyoen know of a web site that has some good info on the TH350 on how to make them stronger?
Old Feb 16, 2006 | 07:55 PM
Guest
Guest
Posts: n/a
anyone?
Old Feb 16, 2006 | 09:24 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
The sprag is weak and some other parts are weak; this should answer all your questions (it's a list of 350 and 400 parts)
http://www.400raptor.com/
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
lanceflame44
Sep 25, 2015 12:28 PM
