84TransAm305
close
- Join DateJan 2006
- Locationiowa
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car2001 ram (prev 84 and 93 ta)
- Engine360 (cold air, exhaust)
- Transmissionplastic stock dodge....
- Axle/Gears...havent looked that far....
- Liked:0 Times in 0 Posts
whats the worst things with these "slush boxes" i have herd great things about them and i love mine cause theres something in it that makes it do a second gear scratch and its outrageus, sometimes its a second gear burn out, there is no shift kit in it, just raw power.
raw 305 power
j/k
Weaknesses are 3-4 pack, sunshell and the lockup clutch as you start to make good hp/tq.
j/k
1991CamaroRslow
close
- Join DateOct 2005
- LocationCincinatti OH
- iTrader Positive Feedback100
- iTrader Feedback Score(3)
- Car1991 L03 700r4 RS
- Engine1987 WS6 Trans AM Lb2
- TransmissionTh350 red neck Performance 3k stall
- Axle/Gears95 Mustang 8.8 built with 3.73s
it's probably been rebuild with a vette servo
1991CamaroRslow
close
- Join DateOct 2005
I have a 91 700r4 core sitting on my porch that was in an S10 with a 4.3, sun shell is completely seperated. My opinion is the main problem with there reliability is line pressure inconsistancy, if built and set right they're decent. One of the main complaints about these trans is that there's a big drop from first to second gear.
i agree with dial 305 and raw power thats just wrong in so many ways
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
Is this a weak link??
yes theres a huge drop from 1-2 because they first gear so tall.gm did that to make up for lack of power in the cars,not for racing.your bettoer off with a 200r4,its got a lower first gear so the drop is not as drastic and the overdrive is a tad smaller than the 700 so youll slow the rpms down even more.and yes they can be built to handle hp
TTOP350
close
- Join DateOct 2001
- LocationIl
There are a few trans guys offering a 2.66 first and 1.5 ratio for the 700r4.. it was supposed to be out in 05 .. Im still waiting
Quote:
Yes it certainly was! Only the speedo gear "may" have survived.Originally posted by Tony Walch
