Trans lines leaking
Old Feb 20, 2006 | 09:46 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Trans lines leaking
My transmission lines are leaking right by the starter on my 3.1l v6. I'm hopefully going to replace the transmission sometime this year with a WC t-5. As I understand it I won't need these lines anymore when I replace the transmission so I would like to have a good reliable fix that will last me 1 - 2 yrs. Any ideas? Should I just cut the line and replace with rubber hose?
Old Feb 20, 2006 | 12:10 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Just run rubber lines. I did that when I had my auto for about 3 years without a problem.
Make shure to flare the ends of the metal lines where they meet the rubber. This helps to prevent leaks later on and makes it a much cleaner install. If you don't have the tool, most places have it for their loan-a-tool program.
Old Feb 20, 2006 | 03:57 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
What he said - I did both of my lines with regular fuel line hose last summer (5/16" IIRC) but then found out that transmission cooler rubber hose is also available. I think it has a higher temperature and pressure rating. If you want several years out of this fix run your hand down both lines to try to find worn or flat areas and fix them now. I only fixed the one line that was leaking and a month later the other line went.
Old Feb 20, 2006 | 07:06 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I took some fuel line I had sitting around, cut the line way after the hole then ran the line back up the line and just left all the crap metal line inside the rubber hose. Hose clamped it and that's that. Think I used 3/16's ID.
Old Feb 20, 2006 | 09:22 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
wayshegoes
Aug 17, 2015 12:00 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Kaweh
Aug 9, 2015 02:54 PM
