2000 ss rear
Old Feb 27, 2006 | 01:29 PM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
2000 ss rear
can i set rid of traction control
Old Feb 27, 2006 | 01:30 PM
In what car?
Old Feb 27, 2006 | 01:40 PM
Car: 85 berlinetta
Engine: none
its out of a 2000ss camaro going into a 85 camaro im trying to figure out how to get rid of the tcs
Old Feb 27, 2006 | 02:16 PM
Why?
Old Feb 27, 2006 | 03:32 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
TCS wont be engaged. the only way it would be engaged is if you hook up the wiring, and if you have the TCS control module that is on the 00 camaro. you dont have to worry about it basicly
Old Feb 27, 2006 | 04:01 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
talk about beating around the bush.
you won't have TCS on your car so you will be straight.
If the rear has the pigtails on the TCS sensors, just unplug them.
Get new brake lines and use the stock brass y block on your car.
Old Feb 28, 2006 | 09:23 AM
Car: 85 berlinetta
Engine: none
now will my gears slide in pretty easy im buying a blown rear for 35 with discs
Old Feb 28, 2006 | 10:42 AM
Zepher's Avatar
Well, do you have 3 series gears (3.23 or numerically higher)? Is the differential still good on the SS rear? If your rear is stock, you should have 26 spline axles and your diff won't work with the SS axles as they are 28 spline.
If the diff is good on the SS rear and you have 2 series gears, you can get a spacer so that your gears will work.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
db057
Sep 4, 2015 07:57 AM
E Rod
Aug 28, 2015 05:17 AM
86IROC112
Aug 21, 2015 07:20 PM
