Swapping rears from one 3rd gen to another
Car: 89 Formula 350
I recently came across a Firebird Formula parts car, it has the Posi rear with 3.27 gears and disc brakes. I want to swap into my 92 Camaro RS that has the limited slip drum brake rear.
My question is it a direct swap? Will I be able to hook up my E brake properly and will I need any other parts?
I do realize my speedo wont work right anymore, any info on what I will need to set that up correctly?
Thanks in advance...
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
1 thing your gonna need the brake booster setup or possibally a proportioning valve. The rear drums on your now take alot less brake pressure to apply than rear disks. When you hit your brakes you wont feel like you have any rear braking.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Swapping rears from one 3rd gen to another
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
