t56 clutchs
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
t56 clutchs
anyone that has done a t56 swap into a 3rd gen i want to here what clutches are good. i'm using a centerforce flywheel and was curious if i could use a newer oem style clutch with the centerforce flywheel or do i have to go aftermarket?
does the oem stlye clutchs good or do they wear too fast?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
T-56 uses a different flywheel then the t-5. As for the clutches I wouldn't recommend a Spec clutch unless it's there stage 4, best to do a search on camaroz28.com for something like this.
Car: 85 camaro z28
you can interchange flywheels and clutches right. like use a centerforce flywheel with a mcleod clutch. as long as it's the right application correct?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, you can use different flywheels and clutches, but make sure the clutch and pressure plate are the same manufacturer. McLeod is a good choice of clutch.
Part# 261871 for the disc
Part# 360822 for the pressure plate.
These are for an LT1 T56.
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I have the McLeod on my setup and it is a little stiff but other than it is great. As long as it is broken in properly, you won't have problem.
Car: 85 camaro z28
i was just curious what people thought about the dual friction clutch from centerforce. is it good? or is there problems?
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Originally Posted by CALL911
quote from this thread
I know SPEC has been looked down at by some, but I would reccomend their clutches. True, my first clutch (SPEC stage 3) when took apart with 10k drivin on it had a missing spring that fell out when I opened the bell housing. After doing some research I found that SPEC has recently upped the quality level of their clutches, and their new ones are nothing like the old ones. This shows because my old one was a #$%@! pain to break in, and when I replaced it with one of the new SPEC stage 3's, it felt like it was already broken in at mile #1! Another reason I like the SPEC clutches is the price. There's pretty much no other clutch rated at the same hp for the same amount of $. BTW, my car is driven about %75 highway, %20 city, and about %5 on the track.
Car: 85 camaro z28
since clutches can become a little expensive does anyone know how good a replacement oem clutch made by Valeo holds up. is it not worth buying or is it safe to buy for car that's not even pushing 275 hp? Senior Member
Car: 87 Iroc Z28
Engine: 355 TPI
Originally Posted by n8sz28
since clutches can become a little expensive does anyone know how good a replacement oem clutch made by Valeo holds up. is it not worth buying or is it safe to buy for car that's not even pushing 275 hp? Thread Starter
Car: 85 camaro z28
does anyone know if you can use a dual friction centerforce clutch on a 2 RMS engine that uses the centerforce flywheel part #700107?
if anyone has used this setup how is it working?
bigjay89gta
Oct 15, 2015 08:04 AM
