700r4 Shifting Problem
Old Mar 12, 2006 | 07:43 PM
arizonai's Avatar
I have a peculiur problem that I can't seem to find an answer to.
I have a 700r4 in my GTA. When the it's cold it shifts perfectly fine. But when the tranny warms up it will no longer shift into 4th (OD). Cold shift is a nice shift around 50 mph, I believe.
Unfortunately I don't know what shift kit is in it, nor can I contact the guy that built it. I have no OD switch and assume there is a check valve in place for OD. I wouldn't know how to figure this out.
But this is really baffeling me. Thanks for your help.
Old Mar 13, 2006 | 02:13 AM
zrated57's Avatar
Are you trying to shift into 4th gear with the throttle 100% depressed? As far as I know, I think you have to let off the throttle to about 2/3 and then it will shift into 4th. I believe they sell something to correct that problem. Maybe do a search. This may not be your problem, but I have had this problem before and that is what I learned. Good luck.
Old Mar 13, 2006 | 07:21 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
kickdown kit
A kickdown kit from b&m fixes that problem. I think that is what your were thinking of?
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
