What benifit will i get switching 3.23's to 3.73's??
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
my 86 IROC came with a gear set of 3.23 posi.. in my quest to make it go faster i was wondering if it would be better to swap them out for 3.73's?? and will 3.73's bolt into place of the stock ring and pinion?
Also- what all might i need for the swap, what is a good price on a set?
All the info on my car is listed on my side bar and my sig.. Thanks guys!!
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
The 3.73s would give you slightly better off the line acceleration with the loss of some top end unless you make mods to put the engine RPM range higher to compensate ... truthfully it wont make a big difference and you can use other mods to gain more speed and keep your cruise RPM down ..
Car: 1986 IROC Z-28
What mods can i use to gain more off the line torque and good 60ft's?
This engine was originaly connected to a TH350 and a 3.73 rear end, it was then carburated and felt like it had lots of power.. since i've put it into my camaro it feels like i've lost some.. Whats goin on there?
Thanks!
Here is a link w/ pics of my Y pipe..
https://www.thirdgen.org/forums/show...42#post2799042
3.73 gears with the Vortec setup and some tuning should be OK. They'll give a helluvalot more than a "slightly" better launch; like, it'll feel like a whole other car. You could also try a converter; something in the 2400 RPM neighborhood would be a big improvement over the stock 1400-1600 RPM.
Car: 1986 IROC Z-28
Of course you have; it has TPI on it now. You'll just have to get used to it.
I have ported TPI stuff, vortec heads, and a bigger engine.. and an ARAP bin set up for the 24# lt1 injectors... and a stock 10 bolt posi 3.23 gear rear
So is my ****ty gearing a big part of my problem?
And i am looking into tryin to get a 2400 stall.. right now it stalls out at about 1800 w/ stock 305 converter...
Whats a good price to look at for gears? ( my stock rear is posi btw) and what should i look for to make sure they will fit?
THanks!!
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Numbah-1
Sep 12, 2015 08:57 PM
Randomtask2
Sep 10, 2015 08:37 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
