GTO Trans
Old Mar 25, 2006 | 11:44 AM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
GTO Trans
Is that the same trans that came in the 4gens??
Old Mar 25, 2006 | 12:54 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I think the manual is the same. But the automatic is newer. Talking about the '06 GTO.
I'm not sure though.
Old Mar 26, 2006 | 06:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its likely a T-56, but the similarities probably end there. It' be made to bolt up to the later generation V8's, wont have a TA mount, will probably have a different case, etc.
Old Mar 26, 2006 | 07:32 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I thought the center case/section with all the guts was the same for all T-56s (mustang, viper, camaro/bird, etc) but they just had different input/output shafts, bellhousings, and tail shafts, not to mention gear ratios and higher quality components in some cases (like viper). Kinda like the LS1 trans can be made to work with a L98/LT1 car, you just have to change a few things.
Could be wrong though. Also, no clue of the GTO uses a t-56 but I'm sure google could answer that.
Hawk312
Aug 22, 2017 08:55 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Omega
LSX and LTX Parts
Aug 26, 2015 06:40 AM
Hello, Michael
Aug 20, 2015 03:19 PM
Leggman1
Aug 6, 2015 04:15 AM
