Will Putting in higher stall w/ electronic lock up hurt my gas mileage??
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Ok- I took my 358 "the one listed below" out of my old 4x4 and put it into my camaro and put high flow TPI stuff on it.. the cam is really high range like 4000-7000rpm..
and when i mash on it around u know like 2300 rpm its kinda doggy, A guy told me to put a 3000 or 3500 stall in it and said i wouldnt notice a difference..
Just wondering if i would or not..
ive got a stock converter in my 700r4 right now..
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I may be wrong but if you put a higher stall on your car your mileage will suffer. That's just a fact. Engaging the electronic lock will improve that however but taking advantage of the higher stall is the whole point of adding it, right?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
u might lose one or two miles per gallon.. i lost about 1 when i went to 2800stall. when it locks up it drives like stock so your rpms are down.
but having the stall converter around hills and slow speeds, its not locked up your rpms will be high and thats where u lose some mileage.
but yeah, once it locks up and ur cruising, you cant notice it there till u mash on the gas.. the difference is amazing. if your high range get 3500stall and enjoy the power rush when u stomp on it.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I went from 18 AVG to 15 AVG. After my 9.5" ACT 2500 flash stall. I do a lot of country road driving, so I'm constantly seeing slow corners and inclines. If I do a lot of interstate driving I can AVG 20-22.
Definitely had more low end grunt off the line even on the stock 350. Steep inclines and ramps can be a PITA until you get use to them.
My advise would be to call a place like probuilt or PI and order a converter. Off the shelf ones are cheaper but there larger diameter (means more stress and less torque output) and there usually rated for a specific torque to reach that flash. Dana wrote down my combo including cam, intake, rear gear, CI, and torque output before picking and ordering a converter. Which meant it cost it a little more, but it wasn't a guessing game on the flash speed it was dead on.
NM noticed you had a ported intaked.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Buy the best converter you have $$$$ for.
Going with a Precision Vigilante would be a safe bet. Or something else like Yank.
They are very efficient converter and might cost u 1-2 mpg around town depending on your habits. Highway mileage will remain the same if its locked up. I actually have gotten very little decrease, however when im off of it, im off of it and when im on it, im on it lol
The lesser converters arent bad per se, just less efficient so it costs u more in gas mileage than a more efficient converter.
later
Jeremy
later
Jeremy
Car: 1986 IROC Z-28
im going to go with a 10" 2800-3000 stall converter I think..
they seem to run about $350 or so +shipping with a year warranty, and rated for 500 hp.. Hows that sound?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It depends how you drive, if your constantly low speed, stop and go making use of the high stall it is going to hurt the mileage a bit. But once you hit the highway and it locks up you will be getting the exact same mileage because no matter what TC you have once it locks up you have a direct 1:1 drive from the engine to tranny.
Car: 1986 IROC Z-28
roysatikas
Sep 22, 2015 08:15 PM
MikkoV
Sep 9, 2015 04:25 PM
