soft shift.
Old Mar 25, 2006 | 02:18 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
soft shift.
I would like to know how do you frim up overdrive shift feel,mine is soft and i have the transgo shift kit installed.
Old Mar 25, 2006 | 07:59 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
You are not suppose to have a strong/firm overdrive shift. When you go into WOT it will not shift into overdrive until you let off, so why bother?
Old Mar 26, 2006 | 12:20 AM
antoine's Avatar
That maybe yours but mine will upshift into overdrive at full throttle.
Old Mar 26, 2006 | 02:38 AM
Pro Built Automatics's Avatar
If you installed the Trans-Go Performance Shift kit, then did you plug (block) the feed hole in the case for the 4th gear feed as per instructions?, and what size did you drill the hole in the seperator plate too?
Old Mar 26, 2006 | 11:59 AM
antoine's Avatar
i pluged the fourth gear feed hole and used the .157 drill bit that came with the transgo kit,now when you plug the fourth gear accumulator hole does the piston and spring still work.?
Old Mar 26, 2006 | 05:54 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
no, the piston and spring no longer work as an accumulator.
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1992Z28!
Nov 19, 2015 07:33 AM
jbates346
Sep 22, 2015 05:22 AM
HikoriYami
Sep 21, 2015 07:11 PM
crazynights
Aug 21, 2015 06:53 AM
