anyone have B&N Kickdown Valve?
Old Mar 28, 2006 | 09:20 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
has anyone intalled the Kickdown valve so the car will shift into 4th at WOT...anyone have this valve with a shift kit?, any issues or problems, I"m thinking about ordering it and having my transmission guy put it in while he's doing some repairs...is it reliable?
Old Mar 30, 2006 | 08:37 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Are you talking about the TV Valve? Or the 4th gear valve on the other side of the valve body?
I got my TV valve from a guy who custom made it at work on a lathe, so that it wouldn't downshift from 4th into 3rd untill 95% throttle.
As for wanting the full throttle upshift into OD, you will want the "B-Car Fix" I have the part # somewere. It was $20.00 at the GM parts counter. I have heard pros and cons on it because some one would install it and it wouldn't shift into OD for them. However, I believe this may have been from the combination of a 2.73 gear, and not enough power to get to the shift point (depending on the vehicle, 4500 to 5500 rpm maybe). With a 2.73 gear 4500 rpm would be around 115-125 mph in a 3rd gen, 5500 would be between 140 and 150 mph. With a stock tbi 305 or a stock LG-4 you are probably not going to get up to that speed in order for the tranny to shift into OD on its own.
My TA has a 3.73 gear and a carbed 355, will it shift into OD at WOT? Maybe, but I am not done with the car yet and have not tried it. Don't think I will either.
Old Mar 30, 2006 | 09:17 PM
Car: 1988 SC Camaro
Engine: 305 TBI
i see...well, now I"m hesitent to get it...i will be getting 3.73 gears and i already have a shift kit installed...i will have some engine mods but i was hoping to hear from more people that installed the valve and whether it actually shifted into 4th gear properly...
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
