What code do I look for to determine gear ratio
92 RS 305 Auto
I'm trying to figure out what ratio gear I have.
The car still has the sticker in the rear compartment, I just don't know which one it is.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Providing it's still original
92 RS with a 305 and automatic transmission has 2.73 gears in the diff. No other gear options available for that package. It will also have 28 spline axles.
If it had a manual transmission, it would have had 3.08 gears.
The axle codes on your sticker start with the letter G. The 2.73 ratio is code# GU2. If you happen to have code# G80 right next to it, that code denotes posi. 3.23 is code# GU5, and 3.42 is code# GU6. I think 3.08 is code# GU3 if I remember correctly. As you can see, the code numbers kinda go in sequence with the ratio (i.e. the higher the code#, the lower the gear ratio).
Thanks everyone, the gear is a 2.73
I found this one
Category - Richmond Gear GM 10-Bolt Ring & Pinion Sets, last catagory 4th one down, can someone tell me if it's the right gear for my car!?
836-49-0007-1 <--part #
Ratio: 3.73, 2-Series <--2 series for 3.08 and lower carrier
Teeth: 41-11
27 Spline Pinion <--I have a 28, is this a problem?
Also do I need any other parts for a complete install?
I found this one
Teeth: 41-11
Car: 87 IROC L98
And yes you need gears to fit on a 2 series carrier.
Originally Posted by Stephen 87 IROC
All 7.5/7.625 10 bolt diffs have 27 spline pinion splines. That's the splines that your driveshaft yoke slip onto. You have 28 spline axles.
Car: 87 IROC L98
Other parts required
New bearings would be nice. You'll need an install kit. The pinion depth is set by a shim under the pinion bearing. The bearing is pressed onto the pinion. It's very difficult to remove the bearing without destroying it. Setting the pinion depth becomes a one shot deal unless you have a special bearing set up to do it. Any shop that sets up diffs will have a bearing with the center machined out slightly larger so that it doesn't need to be pressed on the pinion. They can then easily slide it on and off while changing pinion shims. Your one shot deal is to remove the old bearing from the pinion and take the shims from the old pinion and put them onto the new pinion. Press the bearing on and check your gear pattern. If it's out, you're going to need another bearing unless you can find some way to get the new one off without destroying it just to change the shims.
The install kit will include bearings and races, shims, crush sleeve, gear marking compound, cover gasket, pinion seal and probably the pinion nut. It won't include any instructions.
Just another tip. If you really have to have a special pinion bearing that slides on and off for setup, Reider Racing sells them in a kit. I'm seriously considering one for my future setup since it's pretty much a 99% guarantee you'll destroy the new bearing if you try to press it off again to adjust the shim. Most guys who've set them up say a .030 shim works right almost every time though.
Chevy3shitty
Sep 1, 2015 02:10 AM
hectre13
Aug 26, 2015 08:17 AM
