26 and 28 Spline Shaft by year
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Can someone verify this information to be correct: 1990-1992 camaros used 28 spline axel shaft while the 1982-1989 has the 26 spline shaft.
Close....
There were NO 28 spline units before 89. In 89, about 20% or less got the 28 spline setup. In 90, there were very few 26s left, probably less than 5%; 91 up, they're pretty much all 28s.
89 is the main problem year. Seems like, if you don't look before you buy, whatever you buy will be the wrong one.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
But basically the information that you have is correct and under most situations, that's the axle spline rules you should go by.
That's also only for the 10 bolt. The 9 bolt uses different axles.
Car: 1988 SC Camaro
Engine: 305 TBI
...I'm going to be ordering a ring & pinions, a new carrier, and a master overhaul kit, and the guy from Randys Ring and Pinion needed to know if i had a 26 or 28 spline, so I guess my 88 should have a stock 26 spline...
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
Genopsyde
Oct 7, 2015 08:35 PM
