Manual Tranny - Rough Shifting Once Warmed Up......HELP!
Old Apr 8, 2006 | 02:29 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
Alright so the tranny shifts pretty good when I first start it up. After driving for lets say 10 minutes it gets stiffer and stiffer trying to shift. If I come to a stop after running it is pretty bad. To get into reverse I have to go from 5th first. Normally will go into 1st if I move it pretty slowly in, then its hard to go into second unless I do it a low rpm, I can go from 1st to 3rd or higher pretty easily. Still I have driven other manual cars and it is stiffer than all of them. I was driving a jeep and it would just shift nearly by gravity.
My dads saying its probably a bad master cylinder and he already has got the parts. I was wondering if this was a common problem and if any of you guys could think of something simpler that could be the problem. The car is a 86 Z28 with about 85,000 miles.
Old Apr 8, 2006 | 10:32 PM
1985Irok's Avatar
Car: 1985 IROC
Axle/Gears: factory
The exact same thing is wrong with my T-5. It's not quite as bad as yours sounds, but its enough to be a pain. Mine does well in the morning and in places with little traffic, but when i have to stop and go it acts up real bad. I'm thinking your dad's right. The reason there's resistance is because the clutch is not disengaging. At first I thought I had a bad pressure plate, but then I noticed it had good days and bad days. It wasn't consistent. But yea I suspect my master cylinder's the problem as well. I don't think its pushing the slave cylinder as well as it should be, but i have yet to further inspect mine. In the morning the fluid is colder and more dense, the same as when you first start it, so it works better after a cold start, but once it warms up it goes to crap. I'm not sure what you can do to repair it, but I know you can't adjust it. Just wanted to let you know your not the only one. Good luck!
Old Apr 10, 2006 | 01:59 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
What kind of gear oil are you running in your trans? Ive heard that some of them had a problem if you use the wrong viscosity. master sounds like more the culprit but I was just throwging in a lil extra to think about.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
crazynights
Aug 21, 2015 06:53 AM
