lg4 top speed
Old Apr 9, 2006 | 08:14 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
lg4 top speed
whats the top speed of the lg4? does the lg4 have a speed limiter?
Old Apr 9, 2006 | 08:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No
Old Apr 9, 2006 | 10:09 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
probably around 110, though the speedo is 85
Old Apr 9, 2006 | 11:13 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
when i had my oriiginal motor i had my speedo peged straight down a couple of times not quite sure if this is coredt but we estimated about 120-130mph. it took 11 looooooooooooooooong time and a lot of road to do that but i did it!
Old Apr 9, 2006 | 11:51 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
No speed limiter, no. As for the top speed, someone said the speedo only goes to 85. Well mine is a factory 140 unit. *shrug*
Old Apr 10, 2006 | 12:01 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yours is also in km/h.
Old Apr 10, 2006 | 01:50 AM
305q_ta86's Avatar
Transmission: 5 spd
No, I mean 140 mph. 220k.
Old Apr 10, 2006 | 02:29 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
think '86 was the first year for the 145mph speedo
Old Apr 10, 2006 | 10:39 AM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
135 give or take.
Old Apr 10, 2006 | 10:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I read somewhere that top speed for an L69 was 138. I doubt a stock LG4 could complete with that kind of speed.
JamesC
Old Apr 10, 2006 | 01:53 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
had mine at well over 140 on a couple og occasions course it wasnt just the stock 305 when I had it. Plus manual valve body in the 700-r4 meant it wasn't doing that stupid half throttle downsift that they are notorious for.
Old Apr 10, 2006 | 02:05 PM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
JamesC
headers and exhaust on my car 84 t/a-5sp L69, 3.73
5200 rpm in 5th...took forever but estimates out to 150 ish... with 27in tall tires
Old Apr 10, 2006 | 08:12 PM
Screamin86's Avatar
i had a flowmaster cat-back and k&n replacement filter with the lid flipped when i did my runs. oh and a fresh set of plugs and oil change! that motor had 21x,xxx miles on it too! crazy with the 2.73 gears though i was in 3rd doing about 4000rmp and if i was easing into it in 4th @ about 2500-3000rpm! that was insane!
Old May 28, 2006 | 08:10 PM
1989iroczaz's Avatar
Car: 1989 camaro iroc-z
Speaking of the fullthrottle 4th gear downshift. Does anyone know how to fix this?
Old May 28, 2006 | 08:13 PM
305q_ta86's Avatar
Transmission: 5 spd
You get a new boost valve, I believe. A search will turn it up. Though you had better have done other stuff to the trans so it can take the abuse.
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
InfinityShade
Aug 22, 2015 08:00 PM
