Non EFI olds 455-->454 TBI VSS Install LOOK @ PLZ
Old Apr 11, 2006 | 05:02 PM
EvoTech1's Avatar
Car: Beater 66 442 clone DAILY DRIVER
Engine: stock 400
Transmission: TH-400
Axle/Gears: 12-bolt posi 2.73 14.71et
OK, I have posted on the TBI board, I am trying to learn as much as I can about this conversion prior to going headlong into it SO....
heres the list of sensors that need to go on the old olds.
1.)VSS
2.)IAC
3.)TPS
4.)MAP
5.)Knock sensor
6.)ESC
7.)Electronic distributer
8.)Park/Neutral switch (I got one from the zone for a later model of the same car (GM is pretty generic)
9)A/C on input
The VSS is installed on the rear end right? Could anyone tell me anything about the sensor, how it is installed, and how it works? Anyone with experience mounting these on non stock rear ends have any thoughts on mounting one on an old Oldsmobile 12 bolt?
Thanks for your input.
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
