700-r4 tailshaft onto TH350
Old Apr 14, 2006 | 04:29 PM
85_Camaro_Kid's Avatar
Car: 1985 Chevy Camaro
Engine: 350 2-bolt
Axle/Gears: 10 bolt, 3.23 posi
I just scored a rebuilt TH350 for $125. THe guys wife got pregnate, so yea...That's how it works for some.
Anyways, I looked around for a 82-84 44" driveshaft, but to no avail. Can I just swap the tail shaft off my 700r4 onto the TH350, and use my 94 Camaro V6 alluminum drive shaft with my 10bolt rear?
Old Apr 14, 2006 | 05:12 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
no, the output shafts are different, and so are the tail housings.
the only thing the same is the spline count and the seal and bushing.
you would have to completely disassemble both trannys to get the shafts out anyway...but no, they won't interchange
Old Apr 14, 2006 | 05:29 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
read this thread in the last post the guy used a 700 tail shaft on his th350 https://www.thirdgen.org/forums/tran...n-not-faq.html
Old Apr 14, 2006 | 05:51 PM
Engine: 350 2-bolt
Well, then what do I have to have to swap to a th350?? Forgive me for not searching, but I am a little drunk and I aint feeling like serching.
Old Apr 14, 2006 | 09:08 PM
greggbruce's Avatar
Originally Posted by BanditMan
well, today i got out there and swapped the tailshaft housing on the 350, which is a long tail, with my 700 tailshaft. Everybody has said it wouldnt work, but the speedo gear line up perect and the yoke goes in about 2 inches past the seal, more than enough to hold the fluid in. Why has everyone said it wouldnt work??The yoke dosent have to slide all the way till the yoke ears are right up to the end does it?
if you read carefully, he said tailshaft HOUSING.
which was actually NOT a long tail, because those are about 12" long and your 700 is about 6.
I really am not sure what he is talking about, except for the housing. the SHAFTS are different. which is what you said-- tailSHAFT.
I was answering your question.
I, personally have not tried to swap the housings, but I suppose it would work, the o-rings are the same, the bushings are the same and the driveshaft yokes are the same, I suppose if the housings are the same length then it would work. I don't currently have any short tail 350's around to check if the 700 housing fits, but when I get one, I will check.
Old Apr 14, 2006 | 09:24 PM
91drag's Avatar
Engine: 350,289
actully if camaro kid has a longtail th350 the driveshaft from the 700r4 will fit and for the ta mount get the b&m or hurst kit for a th350 and bolt it in. if short shaft get the ta kit and have a driveshaft built or get one from a 200 trans
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
