t.c.c. lock up switch problem
Old Apr 18, 2006 | 01:47 PM
rock'n z's Avatar
Car: 88 camaro iroc
Engine: 5.7 tuned port
Transmission: 700 r4
well i installed the switch in like the tech article said..... come to find out that all its good for that way is blowing fuses cause its creating a direct short to ground well i looked at the wireing diagram and i connected it directly to the t.c.c. pin at the ecm but yet again to my supprise the fuse blew but not right away....... any one have this problem???? someone knows how to fix it or wire it up correctly??? thanks this is greatly appreciated
Old Apr 18, 2006 | 02:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The tech article doesn't describe a direct short to ground. The TCC solenoid always has +12v to one side through the brake switch, the ECM grounds the other side to lock the TCC. Shorting the TCC test pin on the ALDL to ground accomplishes the same thing. If you're blowing fuses, you're doing something wrong, or you have bad wiring.
Old Apr 18, 2006 | 02:59 PM
rock'n z's Avatar
Car: 88 camaro iroc
i fallowed the insructions to the t but i put the key to the on position and as soon as i fliped the switch the fuse poped
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 9, 2015 01:15 PM
