th350 & lockup converters
Old Apr 19, 2006 | 09:40 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Ok, this is a question about an 81 vette, but a th350 in general.
Friend has an 81 vette, going to go to non CC stuff. Going to remove the computer. The computer is said to "control" lockup. Its said that to keepo the lockup feature after removing the computer, he has to run a manual lockup switch.
In the thirdgens, the computer simply provides +12v to one of the terminals on the pigtail in the tranny which in 4th gear activates a solenoid to lockup the converter. If you remove the computer, you just have to give it +12v feed (that breaks when the breaks are applied)
Is that not the same for the vette with a th350? How does the computer control lockup on a th350 then? It's a vacuum modulated setup is it not?
Old Apr 19, 2006 | 09:49 AM
A TH-350 doesn't have lockup.
A TH-350C would, but that's not what came in a 81 Vette.
Don't worry about it.
Old Apr 19, 2006 | 10:13 AM
Car: 88 Camaro
Engine: 310 LG4
i found this while searching for 81 vetter options
New for the '81 was the lock-up torque converter for second and third gears
http://www.illustratedcorvetteseries...rod_Vette.html
Old Apr 19, 2006 | 10:30 AM
I'd suggest going out and looking at the parts you actually have before believing that.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 2, 2015 09:12 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
