when did they change the 700r4s
Car: 88 Trans am
Engine: high comp vette engine.
Axle/Gears: 308
i have a 88 t\a and it has a plug sensor for the speedometer and the tranny i have has a cable sensor/ the guy told me the tranny came out of a 91 iroc wouldent it have a plug like mine.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally Posted by iroc22
They changed to electronic in 90
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
you will still have to change the vss senser on the output shaft looks like a metal speedo gear.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The drive gear on the tailshaft is the exact same plastic gear for cable and electronic speedos. The metal gear you are thinking of is a reluctor wheel used in 4th gens.
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
