Before installing new rear end should I...
Old Apr 26, 2006 | 05:42 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
I'm swapping rear ends and was wondering if regular paint would hold up or if something else would be in order?
Thanks,
Will
Old Apr 26, 2006 | 07:44 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I just got done with my 9 bolt build, and I went ahead and used gloss black engine enamel, or hi heat I cant remember. either way, Id say use just use some sort of high heat spray paint. just make sure you clean the crap out of the surface and roughen it up a little with like some 150 grit sandpaper. Theres more than likely alot of oil and grease on the rear thats gathe over the years, so just make sure you get all of it off so you dont have to do it all over when the paint peels off.
Old Apr 26, 2006 | 09:03 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
paint? you godda be kidding me right?
unless im wrong which i prolly am,. then why is paint such a factor? im about to do the same thing as far as a swap goes for my rear end on my 91 r/s. and the only thing im worryd about is running into problems im hopeing this swap is alot easier then the automatic transmissions i have been installing??any one know if replacing a rear is any harder?
Old Apr 26, 2006 | 09:12 PM
spills's Avatar
Car: 89 RS
well first off, there are alot of people who paint their rear ends. Some just dont like building up, or even swapping in, a rear thats greasy and rusty lookin. Paintin it just gives it a cleaner look.
As far as swappin rears, it depends on what rear you got. THe main concern for the most part is te brake system. If your goin from drum to disc or vice-versa, there might be a little more involved. If its drum-drum rear swap, majority of the time its just a matter of R&I.
Old Apr 26, 2006 | 10:45 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
I just want to clean it up and make it look nice. I don't want to have to do it twice, thats why I asked.
As for swaping rears its pretty easy, they are not held in by much. I removed the one I want to paint last night in about an hour or so. Just a tip, use small tires or a floor jack to get out/in from under the car.
Will
Old Apr 29, 2006 | 03:53 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I painted my 12 bolt with some high heat (500 degree) black engine enamel.
Old Apr 29, 2006 | 04:58 AM
EvilCartman's Avatar
Car: '82 Z28
Painted mine with regular gloss black paint, no problems. Did the same on another vehicle which goes in the snow every year and the parts that scrape the snow are nice shiny bare metal now hehe.
Old Apr 29, 2006 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Por-15.
https://www.thirdgen.org/forums/atta...g?d=1087748246
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
