What o you recomend for Trans fluid?
Old Apr 27, 2006 | 11:17 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I read somewhere yesterday that Synthetic Fluid is not good for Automatic trannys. The article actually recomended using the various manufacturers fludis. I.E GM's versin of Dexron. Is there any truth to this? What are you all useing? I use Mobil 1 in the engine and I swear by it.
Old Apr 27, 2006 | 11:28 AM
Shagwell's Avatar
Car: projects.......
just run regular dexron III. - whatever brand you like. The synthetics tend to allow clutch slippage. I've had trans' that had problems, switched to regular fluid and work fine. - as for manual trans, a buddy just switched his 10k TKO over to Royal purple and developed a 2-3 grind. Switched back to GM sychro and grind was gone....
- personally, I won't run sythetics in anything. After taking my motor down after 150k, it look like new inside, shell 15w40 it's whole life.- did intake gaskets on my uncle's 88 TPI 305 @ 130k. Mobil 1 it's whole life, 2500-3k oil changes religiously and you should'a seen the gunk in the cam valley...plus, I've seen it take the lobes off of 4 cams(twin engine boat, new motors, new cams, wiped lobes off of 2 sets of cams)....
- seems everyone has a different opinion, thats just mine. - I've beat the crap out of so many motors on regular oil with no problems that I can't justify sythentics.
maroe624
Apr 16, 2017 08:29 AM
spaigo
Aug 21, 2015 07:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
