TH700R4 wiring help needed!
Old Apr 30, 2006 | 08:34 PM
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
I have a 700r4 from an 88 Chevy Astro van that has been built up. My tranny guy rewired the TCC to work with a switch. I want to put it back to factory so the computer will have control. I am installing TPI on my 86 Monte SS using the early 9th injector setup with MAF.
My tranny has two pressure switches and the two wire TCC solenoid. I need help in figuring out how she was wired from the factory. Below is a few pictures to show what I have.
Attached Thumbnails TH700R4 wiring help needed!-700r4-b.jpg   TH700R4 wiring help needed!-700r4-.jpg
Old May 1, 2006 | 01:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Old May 1, 2006 | 07:10 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The drawing above is spot on. If you wanted to have lock up in 4th gear only, you can also wire it that way. I prefer it. With my higher ratio rear gears and my low torque peak on the engine, it makes the car a little more pleasant to drive around town. Just another option to think about.
Old May 1, 2006 | 08:29 AM
toddztoyz's Avatar
THANK YOU GUYS!!!!!!
I have been scouring the internet trying to figure this thing out with out any luck. I wasted a whole day trying to figure this out. I am so close to finishing my TPI swap. I did not realize how many different ways a TH700R4 can be wired! You are a big life saver!
Old May 1, 2006 | 05:34 PM
redcattaro's Avatar
Car: '84 Z28, '86 IROC
Engine: 305, 406
Transmission: T5, Super T10
Axle/Gears: 3.23, 4.10 Posi
anybody know how wire the lockup converter to a switch? i have a '84 camaro which HAD the feedback carb and electronic advance distributor but i swapped older parts in so i can have more control over what my car is doing but now my lockup converter doesn't work and my gas mileage is gettin killed
also my computer has been removed so can the wiring go straigh to a selonoid or straight to the trans? or something?
Old May 2, 2006 | 09:56 AM
toddztoyz's Avatar
Yes. This is the way my Monte Carlo was wired. Basically, depending on how many pressure switches you have and whether or not you have a two wire soleniod or a one wire soleniod, all you need to do is to apply twelve volts to the solenoid to get the converter to lock. Here is a site that I found very informative about controling the lock up converter.
http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
I also have an 84 Z28 that has been de-computerized but I have not removed all the wiring or the computer itself, I just disconnected so I am able to control my lockup with the Diagnostic plug under the dash. Like this
one shown here
https://www.thirdgen.org/torqueswitch
Old May 4, 2006 | 02:06 PM
redcattaro's Avatar
Engine: 305, 406
i hooked a switch up to the connector on the outside of the trans. I hooked power in terminal A and ground in terminal D. I found on the internet someone did it like this but when i did it, it didn't work and the wires got hot and it seemed like i was pulling a huge amperage draw cause my lights would dim out. So then i found that some of the selonoids are self grounding so i unhooked the ground side and now it just does nothing. Any suggestions??
Old Nov 24, 2006 | 05:46 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
I'm tring to put my car back to stock also just like the above diagram......does anyone know where I can purchase the electrical harness like the picture?? Maybe a gm part number? I have a brand new two-wire solenoid already installed
I've searched all over the internet and can not find that and it's driving me nuts
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
apie2546
Aug 8, 2015 07:12 AM
